Gen 3 Gearbox Change to 6 speed
Posted 02 October 2011 - 11:39 PM
Thank you
Russell
Posted 03 October 2011 - 12:16 AM
Repair/replace your current gearbox.
If you have a modified turbo motor, and intend on keeping the car, then its a worthwhile option.
Budget $6k+
Posted 03 October 2011 - 12:22 AM
to start with, it'll probably cost you more than your car is worth, second, although a 6 speed is a nice luxury to have, it's not something you need in your car
you need more than just the gearbox to make it work. gearbox, clutch release fork, clutch, flywheel, tail shaft, 6 speed transmission mounts, 6 speed crossmember, 6 speed shift linkage, 6 speed clutch master cylinder, shift knob, rear diff (if you go R180 you'll need new matching hubs and rear drive shafts). also to consider is going DCCD (so you need the DCCD controller).
in the end of the day it's your time, money and car so do as you like but really i don't see the need for it in the car you have, as alex said, if you had a turbo then it'd be worth considering. as it is, cost vs need doesn't add up.
Rather than just a 6 speed conversion you'd be better off doing a complete turbo converion using a V7 STI cut
If you want something stronger for now why not look into a wrx/sti 5 speed? If it was me, i'd be looking for a straight/similar replacement or repair to what you already have
Posted 03 October 2011 - 12:26 AM
Posted 03 October 2011 - 05:45 AM
Posted 03 October 2011 - 09:07 AM
Sunspares are expensive.cool thanks guys, i didnt know there was that much to go into a 6spd conversion, i do plan on doing a engine conversion, but that is for when i get my opens (2014), anywhere you know of where i can get a decent box? i was thinking of going to sunspares.
Keep a look out on the forums.
What do you think is wrong with your box? What is it doing?
Posted 03 October 2011 - 10:35 AM
Posted 03 October 2011 - 11:21 AM
in full lock the front left wheel feels like it dont want to turn (rotate) it gets to a point in the rotation and jolts, cv's are fine, bearings are fine,and the sync-ro's are going in 3rd and 4th
re: 3rd and 4th have you changed and flushed the gearbox oil yet?
Posted 03 October 2011 - 02:55 PM
Posted 03 October 2011 - 04:05 PM
That to me sounds like the centre diff may be cactus.in full lock the front left wheel feels like it dont want to turn (rotate) it gets to a point in the rotation and jolts, cv's are fine, bearings are fine,and the sync-ro's are going in 3rd and 4th
If I read right you have an NA Liberty, so not really a box breaker. However, centre diffs can go giving similar symptoms.
If it feels OK in a straight line but under half to full lock it starts to jump or shudder that is what I'd say is the problem.
Centre diff replacement can be done with the gearbox insitu.
Posted 03 October 2011 - 11:21 PM
