Intermittent Keyless Entry Problems - Liberty Gen 3
Posted 13 May 2012 - 09:40 AM
As the title states, I'm having intermittent keyless entry problems.
It seems to only happens after driving and not when first getting into the car.
I have two transponder keys and it doesn't seem to make a difference when using either key.
I have never had to unlock the car using the key.. often i have to lock the car using the key.
Posted 13 May 2012 - 12:27 PM
Posted 13 May 2012 - 07:58 PM
However, I guess it's worth a try to replace one of the transponders batteries and seeing if it makes any difference.
I'm thinking it maybe a relay not turning off or something similar.
Posted 14 May 2012 - 12:42 AM
Posted 14 May 2012 - 08:04 AM
Cold weather
Really? Never had any probs last yr at the snow
Posted 14 May 2012 - 09:19 PM
my apologies.
It'd be interesting to know what sort of transmission the transponder uses to lock/unlock the vehicle and where the receiver is located.
Posted 14 May 2012 - 09:38 PM
From memory the key send a radio frequency to lock/unlock the doors and a micro-chip in the key head (read by an antenna around the ign lock) for the immobiliser.
Posted 15 May 2012 - 04:03 AM
Posted 20 May 2012 - 06:52 PM
When i first bought my car, the lady that owned it before me had worn a hole through the little rubber button with her nails,
and a result, all sorts of crud (dirt, gooey human slime etc.) was causing the button to 'short out' and would be very indicisive on letting me lock/unlock my car haha
If you pull apart the remote and get a soft toothbrush and give the circut board a good clean, it may resolve your issue.
I guess maybe, even if the buttons aren't worn, they may be a possibly of crap still getting in there.
Hope this helps!
2000 RX Gen 3 Liberty - Sold
Posted 24 July 2012 - 10:51 AM
First Thing in the morning. The car won't lock or unlock. So I have to use the key to unlock the door. Then of course the alarm gives off. But once started the car will lock and unlock no problems. Just first thing in the morning
Posted 24 July 2012 - 05:15 PM
Posted 28 July 2012 - 03:44 PM
Posted 28 July 2012 - 06:13 PM
Mine's been doing this in the last couple of weeks too, seemed to only happen after driving somewhere. Unlocked fine, upon arriving it wouldn't lock properly.
Yes! This is exactly what happens to me
Though it will be fine for a month and then do it for a week or two..
I think it must be to do with something like a relay so your not able to lock until its turned off, as if maybe it still thinks your key is in the ignition?
Posted 29 July 2012 - 11:19 AM
I had the exact same issue with my car. I thought it had to be the cold hence the first thing in the morning. So i waited till it was working fine then chucked my keys into the freezer for about 20 minutes took them out and the car refused to unlock. So i concluded its gotta be the cold weather, i took it to a key place and they said the cold often saps the life out of your key battery if it is not fully loaded. so we replaced the battery in the key with a brand new one and i havent had any problems even when there is ice on my window. one key place tested the battery b4 it got changed and said it was fine, the other said they had no idea and recommended a brand new battery for the key....so i recommend you get a brand new battery. worked for meFunny cuz I'm having similar problems aswell.
Posted 29 July 2012 - 01:56 PM
I suspected it has to do with something internal in the car (damn ) seeing 14v from the car running, somehow upsetting the suspect part.
Posted 29 July 2012 - 02:31 PM
Interesting, guess its worth a shot!
Posted 29 July 2012 - 10:16 PM
Yeah totally, process of elimination if it still does it after you replaced the battery then you can defo rule it out as a battery issue. I think its like 15 bucks to get a new one replaced at key cutting place. Cheap way to eliminate one of the possibilities if it dosent solve the issue.
Posted 29 July 2012 - 10:26 PM
so it's been working fine the last few weeks haha but next time, i'll def be replacing battery.
Posted 29 July 2012 - 10:35 PM
It's funny though, as I've mentioned it's intermittent.
Always the way!!!
