Posted 11 December 2013 - 04:31 PM
No, nothing wrong with the gauge at all. Because of the split tank (the tank sits in front of the rear axle, and has the tail shaft tunnel in the centre of it), the low fuel light comes on a bit earlier than a car with a tank behind the rear axle. Turbo Gen 3's are bad for fuel surge at low fuel levels because of the split tank (if thrashing, they arent too bad for normal driving, as less cornering force gives the tanks more time to share their fuel loads). The higher pickup point of low fuel light helps this to a degree.
