guys your all looking it wrong... if he is getting popping sounds from speakers at certain frequencies ( i'm assuming bass end of the spectrum) this is whats called Clipping... and in my opinion the noise from the tweeters is from them being fried...
do some reading on how much distortion comes from these amps... they are rated at 45w or 50w but this is generally PMPO peak music power output and this can last for a second and be of almost 100% THD ( total harmonic distortion... ( my old high school metal band for a side note! )
most H/U do 16-18w RMS (root mean squared) at 1khz at about 10% THD which is where you look at if your chasing pleasing numbers and average audio quality...
if they were to measure across the audio spectrum 20hz to 20khz you would find they would be capable of maybe 10w RMS from 20hz-20kz...
as you ramp up the LEVEL ( often incorrectly reffered to as volume) so to does the distortion... most people kill speakers ( as i am 10000000000% assured you have) by underpowering them.... becasue the voice coil in the speaker plays back more distortion than music...
the popping you would hear is your speakers way of asking you to not torture them any further... its a cry for help!
Power is clarity... and once properly worn in and not played loud as soon as installed any speaker with a decent amount of power ( even 50w RMS will crank! ) and a quality source will sound great!
i have had plenty of systems with sub par speakers and a good amp that has sounded great!
i once ran 100w RMS into my 98 RX Gen 2 speakers for over 2 years... and i thought they handled power very well!!!
moral of my story... it has 2 parts... start simple and look at the basics before you look at earths and wiring and faulty H/U and 2 get an amp and a new set of speakers....
Well I can say the speakers them selves sound good and I don't hear any static from them when the volume is turned up and there is no sound but the tweeters seem be the only ones making static so maybe the inline coil crossover thing?
I honestly don't like the cross over and I was thinking maybe it is that since the tweeters attach directly to the speaker threw that coil.
read my post above... of course you wont hear static down low... the speakers arent playing back the distortion they are being fed...
but they are when you crank it up!
7th: 2002 B4 Liberty TT....
