Centre Diff - so i think i have a problem.
Centre Diff i have a problem
16 replies to this topic
#1 Tim.
Tim.
  • 2024 posts
Posted 01 July 2013 - 04:23 PM
Ok, so lately i've been hearing noises and i'm thinking the issue is related to Centre Diff. My car is a Manual 2001 Liberty RX with TT conversion.
The symptoms are:
- Low speed full lock turns in carparks, there is a slight clunking and the car sort of lurches
- Only happens when car is warm, ie. you've been driving a while. Not noticeable when cold
- No issues when driving straight or cornering.
Things my mechanic has done recently to try fix this issue: Front CVs, Wheel Bearings and hubs replaced.
Drivetrain is out of a 1999 JDM Legacy RSK
Has anyone had a similar issue in the past or care to diagnose over the interweb?
#2 Delete This Account
Posted 01 July 2013 - 04:44 PM
It's fucked.
Wouldn't have happened in a real B4, Timmy. :D
#3 Tim.
Tim.
  • 2024 posts
Posted 01 July 2013 - 04:46 PM
Haha! If I had wanted a response as helpful as that, I would've PM'd you Tom.
Real B4's have aids.
#4 Staxta
Staxta
  • 651 posts
Posted 01 July 2013 - 05:18 PM
My gen 2 had a similar problem, it would clunk once warm, my problem was with the rear diff though.
#5 Dimeb4g
Dimeb4g
    Formerly EOS Heritage
  • 727 posts
Posted 01 July 2013 - 10:35 PM
its called torque bind in autos.... google torque bind on SLI.net and the like and see what happens....
7th: 2002 B4 Liberty TT....
#6 Tim.
Tim.
  • 2024 posts
Posted 02 July 2013 - 08:05 AM
So yeah pretty sure it's a diff. It's just a question of which one.
Not sure if torque bind is the cause as it seems to affect the 4eat automatic transmissions.
#7 sbv
sbv
  • 411 posts
Posted 02 July 2013 - 08:55 AM
Pretty certain it's your centre diff, especially if its really only when doing a sharp turn at low speed. Your description sounds spot on.
#8 Samwise
  • 8434 posts
Posted 02 July 2013 - 09:02 AM
I have this, had it for a couple of years now.
Ben (Ichiban) thinks centre diff.
Should probably fix it haha...
#9 vicelore
vicelore
  • 1579 posts
Posted 02 July 2013 - 09:07 AM
I get it allot but ive got a early DCCD box with no auto(Off switch)
I did hear allot of stuff about auto`s and it being a easy fix..
#10 bmack_01rx
bmack_01rx
  • 6 posts
Posted 02 July 2013 - 12:52 PM
My folks had this same problem in their 2001 Outback. apparently to fix it you need to change the oil in a chamber somewhere around the centre diff / gearbox location (Dad wasn't exactly sure where it is). But the problem is the chamber is sealed and thus you need to buy a whole replacement unit.
I guess this isn't going to help much if I don't know what it's called but that's how my folks got theirs fixed.
#11 Tim.
Tim.
  • 2024 posts
Posted 02 July 2013 - 12:57 PM
Yes, the Viscous Coupling, which is also called a Centre Diff. It is a sealed unit and therefore is not serviceable.
#12 Matty_Lib
Matty_Lib
    rslyf
  • 138 posts
Posted 02 July 2013 - 02:47 PM
IIRC The centre diff can be pulled down and the viscous coupling and gears can be removed for inspection/replacement. But the coupling itself isn't serviceable.
#13 vicelore
vicelore
  • 1579 posts
Posted 02 July 2013 - 02:48 PM
And is expensive.. Piece of shit they are..
#14 Tim.
Tim.
  • 2024 posts
Posted 02 July 2013 - 03:21 PM
Sounds about right.
29 in the image:
#15 vicelore
vicelore
  • 1579 posts
Posted 02 July 2013 - 03:36 PM
Ive herd about buying it from the states as they are allot cheaper.
#16 Matty_Lib
Matty_Lib
    rslyf
  • 138 posts
Posted 02 July 2013 - 04:12 PM
If your viscous coupling is the problem you're having, I may have a spare if you need it. Out of a gen 1 liberty box, but I'm unsure on compatibility.
#17 Tim.
Tim.
  • 2024 posts
Posted 02 July 2013 - 05:22 PM
There is a Phase 1 which is up to 1998 and Phase 2 which is 1999 onwards.
So i'll be needing a Phase 2. Thanks for the offer.
Also tagged with one or more of these keywords: Centre Diff, i have a problem
