Subaru Legacy B4 - Help Needed - Guess That Connection
41 replies to this topic
#1 AB501UT!0N
AB501UT!0N
    Blitzen...
  • 1100 posts
Posted 10 April 2014 - 01:44 PM
Hi guys do any of you know where the two ground wires go that I have circled and also where the white / grey clip goes and it one has one brown cable going to it? Thanks a million!
Also a map of where all the ground wires go would be great :) Thanks so much
Chris
#2 AB501UT!0N
AB501UT!0N
    Blitzen...
  • 1100 posts
Posted 15 April 2014 - 12:19 AM
Anybody ? :(
#3 jack_keaka
jack_keaka
  • 688 posts
  • Interests:I was saying "boo-urns"
Posted 15 April 2014 - 12:42 AM
Buy one of those grounding kits. People reckon they help.
...and that's all I can help... Not that it was help... Bye
#4 AB501UT!0N
AB501UT!0N
    Blitzen...
  • 1100 posts
Posted 15 April 2014 - 10:32 AM
Thanks trying Jack :) any updates on your car?
#5 jack_keaka
jack_keaka
  • 688 posts
Posted 15 April 2014 - 12:05 PM
Yeah, just a few pieces left to put back on and then she is up for sale!
#6 sbv
sbv
  • 411 posts
Posted 15 April 2014 - 06:20 PM
Hi mate there should be a single earthing cable directly between the 2 points you have highlighted as far as I'm aware. I'll double check on the grey plug when I'm home but I think that might belong to a sensor underneath your alternator. I have a feeling it goes underneath the alternator and there is a small brown plug at the front of the block.
#7 sbv
sbv
  • 411 posts
Posted 15 April 2014 - 06:49 PM
Sorry the grey plug connects to a white plug/blue cable which seems to come from the back of the power steering pump.
#8 AB501UT!0N
AB501UT!0N
    Blitzen...
  • 1100 posts
Posted 16 April 2014 - 12:43 AM
Thanks so much for the info and d you know where the other end of the earthing cable should go? Thanks Chris
Up for sale! What are you planning on replacing her with?
#9 sbv
sbv
  • 411 posts
Posted 16 April 2014 - 08:05 AM
The earthing cable straddles between one of the bolts holding the intercooler support to the manifold and behind the washer bottle to a bolt that sits between the two washer bottle bolts. If that makes sense. Exactly where you have circled.
#10 AB501UT!0N
AB501UT!0N
    Blitzen...
  • 1100 posts
Posted 16 April 2014 - 10:12 PM
Thanks so much mate and I shall let you know how I go putting it back together on Sunday/Monday :)
#11 sbv
sbv
  • 411 posts
Posted 16 April 2014 - 10:46 PM
Good luck mate. Get that red rocket back on the road!
#12 AB501UT!0N
AB501UT!0N
    Blitzen...
  • 1100 posts
Posted 26 April 2014 - 08:09 PM
So I have replaced the intake gaskets and repaired the black turbo intake pipe and it as good as new :)
Now to put it back together again but I still cannot find where the small grey plug goes???
Any pics Mr sbv :)  ?
#13 sbv
sbv
  • 411 posts
Posted 27 April 2014 - 09:26 AM
It's just a single blue wire that comes out the back of the power steering pump. It's difficult to get a pic of without pulling things apart.
#14 U-Shell
U-Shell
  • 820 posts
Posted 27 April 2014 - 06:25 PM
+1 on upgrading the grounding points! I ran 2 gauge for the main engine to chassis and chassis to battery grounds, then went around and undid all the smaller grounds for lights/ senors, cleaned them, removed the paint underneath them, screwed them back in. The car started quicker and starter motor was quieter, interior lighting and headlights never dimmed, windows went up and down faster.
Black intake piping looks the goods. Better than the chrome IMO :)
2000 RX Gen 3 Liberty - Sold
#15 AB501UT!0N
AB501UT!0N
    Blitzen...
  • 1100 posts
Posted 27 April 2014 - 11:35 PM
Thanks for the info mate I shall have a look after work tomorrow and I shall clean the pumo cause its rather dirty and that might make it more clear to see :)
I might have to do that but first I just need to get the car started... And then I can relax for a bit :P
And once its running back to normal then Subaru car meet here I come :)
#16 AB501UT!0N
AB501UT!0N
    Blitzen...
  • 1100 posts
Posted 30 April 2014 - 11:57 PM
So I have put it back together and the only sign of life is beeping when the key is in the ignition :(
Can some please post a pic of how their cars battery is wired? Thanks Chris
#17 allpaw4
allpaw4
    Chief Sparky
  • 2182 posts
Posted 01 May 2014 - 12:51 AM
Do you still have the brandt alarm system in that thing Chris?
If you do, its likely you need the master code to do a reset - if its not that, it may be a module of the alarm has failed, and needs replacing.
Mine needed both of those items at various points - if it needs a new module, better off with a new alarm...
I seem to remember mine made incessant beeping when key was in the on position, with not much else happening. I still had dash lights and things though. If you have nothing with key in the on position, somethings not right. Check all fuses in both the main fuse box under the bonnet and also the one above the accelerator pedal behind the panel.
#18 sbv
sbv
  • 411 posts
Posted 01 May 2014 - 07:00 AM
Double check you have two connections on the starter motor.
#19 AB501UT!0N
AB501UT!0N
    Blitzen...
  • 1100 posts
Posted 01 May 2014 - 12:59 PM
I never had the brandt alarm system on the car cause it is an import and it has not security other than one key :P
And I shall check the fuses tonight and double check the earthing aswell!
Both connections are on but I have no lights on the dash so something else before the starter motor is at play I think :(
#20 AB501UT!0N
AB501UT!0N
    Blitzen...
  • 1100 posts
Posted 01 May 2014 - 11:29 PM
So I re did all the earthing connections and re did the battery wires as well and I then check and the main fuse was dead and lucky me I had a spare! And I turned the key and I have lights on the dash and the fuel pump is whiring and all the other good noises but I want to check everything before I turn it over and I will also top up the fluids as well :) So things are looking up
