Heavy duty clutch kit for B4 & gearbox bearings
Posted 15 September 2015 - 01:21 PM
Firstly, what clutch kit would you recommend?
Secondly, the gearbox has always had a whistling/wurring sound since I owned it. It's done 30,000km with no real change. I was told it was the transfer bearing. Where can I order this bearing from? I'd like to fix it while I replace the clutch.
Thirdly, is there any other gearbox related parts like bearings I should be replacing or looking at while I am at it?
Lastly, what seals might leak on to the clutch? I want to replace these too.
Thanks for the advice.
Also forgot to mention it is a 2002 MY03 3GEN Liberty B4.
Posted 15 September 2015 - 03:15 PM
hmm not too sure about the whine it might be normal
They have a pretty good diameter size clutch so probably an execdy replacement and you can go for a heavy duty but it might not have as smooth of a pedal feel/have bit of shudder and get the flywheel machined
As far as the leak the big one is rear main seal thats a given to change when the box is off it can leak given time
Also there is a small bearing in the flywheel that should be replaced at the same time
Posted 15 September 2015 - 03:24 PM
I doubt the whine is normal. You can hear it in most gears, the middle 3 gears are quite noticeable. It is loudest in third.
Posted 15 September 2015 - 05:13 PM
Never driven on just had a few gear changes whist on stands. Send me a PM if interested.
Posted 17 September 2015 - 10:11 AM
Trying to track down a transfer bearing. Any one have part numbers or details that might help?
Does that bearing have a particular name? Is it not included in the clutch kit?
Posted 17 September 2015 - 11:55 AM
For part#'s (and factory parts)
https://partsouq.com/
Flywheel bearing would not normally be in a clutch kit
#7 Guest_KONG_*
Posted 17 September 2015 - 12:59 PM
Spigot bearing.
Posted 17 September 2015 - 05:26 PM
Posted 21 September 2015 - 11:34 AM
Thanks for the suggestion,
I've already purchased an Exceedy HD cushion button clutch kit from Reevsy. Hopefully the gearbox is strong enough. Don't think the kit has a spigot bearing so I'll order that.
I have access to a hoist down on the coast so I'm going to crack out the stethoscope to figure out what bearing is making the noise. I was just going to leave the car there until I got all the parts but I got rear-ended in my wife's Impreza so our insurance might have her car in for repairs...if they don't just write it off. On that note...anyone reckon I can find a Forester GT for around 5k?
Posted 02 October 2015 - 09:34 AM
Hey guys.
I pulled the gearbox out and discovered it was leaking tran oil into the clutch. Since the gearbox has to be split the box open I decided to replace all the bearings.
I have got all the Subaru part numbers from PartSouq. Because of the terrible exchange rate the parts will cost me $420 including postage.
Any suggestions how I might find replacement parts cheaper?
The parts I'm after are:
Posted 02 October 2015 - 05:55 PM
Posted 03 October 2015 - 07:05 AM
We know one of the bearings is stuffed in the middle of the box somewhere so we elected to replace all the main bearings.
Also tagged with one or more of these keywords: Clutch, Gearbox, Bearings
Model Specific →
Impreza / WRX / STi →
Engine / Driveline →
Total gearbox fail at 136,000 km on 2010 Impreza XV AWD. Is this normal?Started by Redzircon, 11 Jan 2020 fail, gearbox, replace |
Tech: The basics →
Suspension / Drivetrain / Rims →
Anyone DIY’d their front wheel bearings?Started by El_Freddo, 26 Oct 2019 Bearing, bearings and 3 more... |
Model Specific →
Liberty / Legacy / Outback →
Slipping out of 3rd and 4th at light cruiseStarted by El_Freddo, 05 Jul 2019 Gearbox, Liberty gearbox and 5 more... |
Model Specific →
MY15 WRX air con and gearbox bearingStarted by PeterWRX, 14 Feb 2018 MY15, WRX, A/C, gearbox |
Tech: The basics →
Twin Turbo →
6 speed conversionStarted by LukeFranky, 06 Oct 2015 gearbox, 6 speed, transmission |
