Gen 3 Liberty RX EJ251 5spd manual, 418,000km, still pulling like a freight train.
The issue reported from my sister (her Liberty) is that at light cruise speeds around town the gearbox will slip out of 3rd and 4th. It initially started out with only skipping out of 4th. Its now progressed to 3rd.
It does all country kms and she doesnt rest her hand on the gearstick when she drives.
Im thinking it could be a broken/worn dedent spring on the 3rd/4th selector shaft. Dad mentioned today that it could be the gearbox mount as the gearstick moves forward/backwards when you let on and off the throttleor vice versa.
Anyone got any other thoughts on what I could be? Its easy to think its mounts after 418k km. Engine will be coming out shortly so Id like to button this issue up while everything is apart.
It also stalls when slowing into take a corner through an intersection if you let revs drop too far between gear changes. Is this just the IACV doing stupid stuff or is it :fork:d? No clheck engine light and Im yet to check for codes before pulling the battery.
Slipping out of 3rd and 4th at light cruise
Started by El_Freddo, Jul 05 2019 09:24 PM
Gearbox Liberty gearbox slip out of gear gear slip 3rd 4th gears?!
4 replies to this topic
Posted 05 July 2019 - 09:24 PM
Posted 07 July 2019 - 06:51 PM
My guess is too much end float on 3&4 mainshaft gears or worn selector sleeve springs.
I'm thinking the box needs to come apart. Is it worth putting in a second hand unit with less kms?
Posted 08 July 2019 - 02:08 PM
It probably is worth putting a second hand gearbox in - and it wouldn’t be hard to do, plus I’ve got one wait so I might as well go for it.
The other thing that swayed me to swap the box was a bearing noise when driving it. I can hear it in neutral with the clutch engaged, in high and low range but not when I’m in neutral between high and low range with clutch engaged. So it’s deeper in the box than just an input shaft bearing - which I was hoping would be the culprit.
With the engine out (doing HGs, cam belt etc) I found the spigot bearing was totally shagged. Only had five balls left in the bearing, no dust cover, no lube... and it didn’t make any noise in the car either.
Posted 07 October 2019 - 04:42 PM
Jase, you were spot on the money - too much end float in the upper shaft. Issue was a dead/dying bearing between 4th and 5th gears.
The replacement box had a dead centre diff, so now it’s time for surgery to make one good box from two. Front diff bearings will be replaced while I’m in there. I split the front cases to check things out - it all looks good.
Posted 08 October 2019 - 06:27 PM
Glad to hear you have it well sorted!
Also tagged with one or more of these keywords: Gearbox, Liberty gearbox, slip out of gear, gear slip, 3rd, 4th, gears?!
Model Specific →
Impreza / WRX / STi →
Engine / Driveline →
Total gearbox fail at 136,000 km on 2010 Impreza XV AWD. Is this normal?Started by Redzircon, 11 Jan 2020 ![]() |
Model Specific →
MY15 WRX air con and gearbox bearingStarted by PeterWRX, 14 Feb 2018 ![]() |
Tech: The basics →
Twin Turbo →
6 speed conversionStarted by LukeFranky, 06 Oct 2015 ![]() |
Tech: The basics →
Twin Turbo →
Heavy duty clutch kit for B4 & gearbox bearingsStarted by LukeFranky, 15 Sep 2015 ![]() |
Tech: The basics →
General →
Anyone do their own gearbox work? Got a question...Started by El_Freddo, 09 Mar 2015 ![]() |
