Fuel choice - E10 or not?
Posted 23 October 2012 - 11:28 PM
Has anyone on here compared the performance and economy of various fuels (E10, 91, 95, 98) in an Impreza R ?
I do quite a few k's so I'm intrested to see if E10 may bring some benefits to the scooby.
Any thoughts or experiences anyone wants to share?
Posted 23 October 2012 - 11:40 PM
Posted 24 October 2012 - 05:18 AM
It's cheap, Usually rated at 94RON, Won't destroy your cars fuel system as it's made up of plastic and alloy (With the exception of rubber o-rings in the injectors and the in tank fuel filter assembly)
I've seen cars that are hitting 450,000km's+ that have run E10 since day one and they haven't had one problem.
I use it every day in the outback and I'm not turning back. Ethanol is great.
98RON fuel is for performance cars and some will tell you it's going to give you better economy and clean your engine, I doubt it.
I've done tests and E10 ticks all the boxes.
It's not for old cars, Your Impreza R is not an old car.
Posted 24 October 2012 - 06:16 AM
My vote would be to stick with 98.
Posted 24 October 2012 - 06:29 AM
Falcon gets e10 and reg unleaded cause i dont give a fark.
Posted 24 October 2012 - 06:35 AM
I never said 98 isn't better.
Posted 24 October 2012 - 06:59 AM
Posted 24 October 2012 - 08:30 AM
Sounds like your saying it is better there, maybe im miss reading it though..
But i am curious as to what tests you done etc??
Because if i can save 20cents a litre on fuel, have a cleaner engine and get better fuel ecconomy while not loosing any performance (because lets face it i barely have any as it is) i would like to know
Posted 24 October 2012 - 09:08 AM
Running BP 98, 95 and E10.
Each was given 10 litres at the exact same time, Exact same room. Running the same rpm cycles.
They all used fuel at around the same rate.
I like E10 because I get the exact same results running E10 compared to 98 for less money.
Run your car on E10 without the idea of it being the devils work and post results.
Posted 24 October 2012 - 09:19 AM
Is that with just leaving them running for the same amount of time? Not actually driving them?
My wife came up to me one night (giggidy) and complained that the SP20 was running really rough and felt sluggish to drive. I asked her what fuel she used last. She was scarily close to empty a few days earlier so had to use E10 at the local BP (couldn't find the only 95 pump) in the station.
I asked her to fill up with 95 next time and see if it makes a difference.. It did and has never has the problem again.
In-laws also had lots of issues in their Accord after running E10 for about 18 months.
Posted 24 October 2012 - 09:28 AM
Ive used plenty of different fuels, and consistantly get better fuel ecconomy out of bp 98, compared to there 95. And so does everyone else i know who's used it.
Anyway not that ive done any reaearch into it but why cant i use e10 in my boat of its as good as any other fuel?
Posted 24 October 2012 - 09:30 AM
Ran the exact same benchmark on them all using 3 laptops.
Posted 24 October 2012 - 09:32 AM
Don't know much about boats.
Posted 24 October 2012 - 10:01 AM
Posted 24 October 2012 - 10:34 AM
Ive noticed a few petrol stations have 'not for marine use' on the e10 pumps.
4 laptops for 3 engines?
Posted 24 October 2012 - 10:40 AM
Never use E10 in a boat engine. It eats away fuel lines, diaphragms and causes all other sorts of havoc.
We see at least 1 boat a week come in which has been run on ethanol and it usually costs them big dollars to fix.
Posted 24 October 2012 - 10:42 AM
Some people have positive experiences with it and some have negative. Everyone will base their judgement on those experiences and that will work for them
Posted 24 October 2012 - 10:50 AM
Cheers for that!
Posted 24 October 2012 - 11:28 AM
Posted 24 October 2012 - 11:30 AM
