Posted 08 April 2012 - 02:39 PM
http://www.licmotors...06-wrx_20002145
I stumbled accross this and I am wondering if this may be a good option? Theres a few different thicknessess but thicker would be better wouldnt it?
Any input would be greatly appreciated.
Cheers, Ryan.
MY95 Liberty Wagon (Silver)
(With lots of Extras to come)
Posted 08 April 2012 - 03:04 PM
1) Avoid aftermarket headgaskets. General consensus is that they're more trouble than what they're worth, and I know lots of people running stupid power figures using just the standard STi MLS (multi layered steel) head gaskets with brilliant results.
2) In terms of ordering new parts: I found this website absolutely a wealth of information in terms of ordering parts and what not. For information pertaining to your Forester, click here. According to this website, it says you require one of four head gasket part numbers. I'm not sure which year model yours is, but its just a guide so that you have an idea what to order when you order parts.
Also helps having some exploded diagrams, and you can also see what other sundries require ordering too
Hope this helps
Posted 08 April 2012 - 03:07 PM
get the gasket kit off here: http://www.risingsun....au/Service.php to suit EJ255 motor (quote your model when asking)
also, just curious on how you came to the diagnosis of HG failure?
Posted 08 April 2012 - 03:28 PM
Was overheating and changed the thermo, got the system flushed and bleed. Still overheating and the overfolw was overflowing and had a heap of bubbles showing up in it. Took it to a family friend who is mechanic and after looking at it and what the overflow and the header tank water levels where doing he determined it was a head gasket. I trust his verdic and he said we could do a TK test to 100% confirm him but in his honest opinion it has failed. He would rather not have to replace it and he is doing the work for next to nothing so makes me trust his judgement even more. Think I will just run the OEM gasket and new head studs, seems to be the way to godon't go aftermarket. if the car is fairly standard stick with OEM stuff. car is tuned to run a certain compression ratio which can be altered by changing hg thickness. get the heads shaved/serviced (Servicing is optional depending on km), new head gaskets, new head bolts (don't reuse old ones) and put it back together.
Yeah cheers Alex, will start reading through this now.Ryan,
Hope this helps
Posted 08 April 2012 - 04:37 PM
Posted 08 April 2012 - 04:39 PM
Dont stuff around with, oversize, undersize stuff.
Your motor is standard and will run fine with standard stuff
Posted 22 April 2012 - 04:43 PM
Found this one on ebay from the states, seems to be genuine and It saves me $100 or so. Thoughts?
http://www.ebay.com....984.m1423.l2649
Posted 22 April 2012 - 04:53 PM
Also tagged with one or more of these keywords: Head Gasket
Tech: The basics →
Naturally Aspirated →
Impreza 2.5rs Head Gasket ConcernsStarted by Joshscubie, 27 Jul 2017 Repairs, Impreza, 2.5rs and 1 more... |
Model Specific →
Forester →
Engine / Driveline →
Change Head Gasket or not? First Post - EJ251 ForesterStarted by peterg, 05 Mar 2017 Head gasket, cam pulley tool and 2 more... |
Suby Club Community →
General Discussion →
Please help! EJ207 issue. *Very paranoid*Started by K.Tonic, 03 Oct 2016 Head gasket, overheating, ej207 and 2 more... |
Tech: The basics →
EJ22E - Potential headgasketStarted by Barbbachello, 06 Jun 2014 EJ22, head gasket, fek and 1 more... |
Tech: The basics →
Not Happy with Local dealer!!Started by Dimeb4g, 17 Jan 2012 sERVICE, Head gasket, rip off |
