Posted 19 February 2009 - 06:22 PM
Posted 19 February 2009 - 06:31 PM
Posted 19 February 2009 - 06:46 PM
Posted 19 February 2009 - 06:52 PM
On my vipec, I've got a digital input setup with a switch to change between boost maps, one for the Mrs and one for me
Posted 19 February 2009 - 07:05 PM
the AVCS is variable, there's a cam timing map for that. The lift actuation isn't variable. Playing with the AVCS around the lift actuation point will help smooth it out, but will take quite a bit of dyno time ($$)
Here's an example of an AVCS map from a V88 Vipec:
Just Married
Posted 19 February 2009 - 07:29 PM
Ahh the Ancient Japanese art of Choo-Ning......You could set a digital input as an over-ride for the solenoid output, then add a switch which goes to ground on that input. when switch is on, it actuates the lift solenoid, when it's off, it works on the target map.
Posted 19 February 2009 - 07:33 PM
Just Married
Posted 19 February 2009 - 07:39 PM
Posted 19 February 2009 - 07:42 PM
Yeah, cos' I was thinking of those I know who have a Race Spec tune and a Street Spec tune, and could only imagine the sort of wear the engine would have from swapping between them too often. But that would be a useful idea, to tame the car back in one tune, and just push the limits a tad with the second. If P-platers were still allowed to drive turbos it'd be a good way to warm them up to the car, by tuning it back and gradually up-speccing. And the old man could still thrash it with his own tune......It wouldn't be harmfull for the engine to swap between tunes if both the tunes are "safe". it all depends on the tunes But I'm assuming that his tunes are pretty much spot on. probably just dropped the boost on the Mrs' tune and smoothed the band out.
I guess I should put up a thread about my own car.
Jason
Posted 19 February 2009 - 07:45 PM
Posted 20 February 2009 - 09:06 AM
Posted 20 February 2009 - 11:10 AM
Posted 20 February 2009 - 12:17 PM
Tristan, don't put an RX kit on it.
Don't fix the paint. Leave it as it is.
Spend your time and money on the engine.
Posted 20 February 2009 - 01:08 PM
Posted 20 February 2009 - 01:35 PM
Posted 20 February 2009 - 02:51 PM
Swaybars. Front and rear. 22mm+...
Then some big f*ck off brakes. Why not?
Then possibly look at some braces, if in future you do find some rainbows and leprechauns inside your motor that will let it make *maxpowahz, the torque won't twist the chassis.
What arse end is in it?
Can you get a 4.44 R180?
Posted 20 February 2009 - 03:59 PM
Posted 20 February 2009 - 04:23 PM
Why are the rears only 277?? Im not sure about the GTB's but the B4 has 290mm Rears as stock.
Posted 20 February 2009 - 05:23 PM
Posted 20 February 2009 - 06:36 PM
