H6 engine
710 replies to this topic
#521 CRUISN
Posted 20 February 2009 - 08:32 PM
Why are the rears only 277?? Im not sure about the GTB's but the B4 has 290mm Rears as stock.
Gen2 GTB rear calipers are the same as GT 277mm calipers, but have different backing plates to make them suit a 290mm rotor. Fitting the calipers alone to anything other the Gen2 GTB will see them only suiting 277mm rotors, but they are vented.
#522 Blaeven
Blaeven
    The Renowned
  • 1,400 posts
Posted 21 February 2009 - 12:11 PM
60:40?
So its mainly FWD, or did you get it backwards?
By "Its not a lock diff" I presume you mean its an open center? :P
40:60 then...
either way... it's a 40 - 60 split with more power going to the rear...
and yeh, its a regular old RX open centre diff...
How are them teins going? Not too rough on the road?
Thought about an outback front bar colour coded? It would look errrm different
i was talking to shiv about that a few nights ago...
that was something i'd been thinking about for a while...
i guess if i hate it then i can just put the GX bar back on...
and i'm sure teh outback bumpers would be easier to source than RX kits...
the teins are alright... though one of them is still knocking and al reckons it was half seized up...
#523 Jeff
Jeff
  • 528 posts
  • Interests:Lee
Posted 21 February 2009 - 12:15 PM
you can get those coilovers "serviced" can't you?? how much do you think it would cost to get them back to original working condition?
Just Married
#524 Blaeven
Blaeven
    The Renowned
  • 1,400 posts
Posted 21 February 2009 - 12:19 PM
i spoke to fulcrum (who service the teins) and IIRC it was about $300ish per strut...
not cheap...
but worth it i guess... cos then it's like i have new tein coilovers for $1900 ($700 original cost)
#525 Jeff
Jeff
  • 528 posts
  • Interests:Lee
Posted 21 February 2009 - 12:26 PM
are they all bad or could you do 2 at a time??? do the front 2 first and then after 2-4 weeks get the rear done??? least then its not such a big hand out of the mulah in one go I'd personally just get the whole lot done at once and be done with it........... although i can't talk, i cant even get my FMIC done.....lmao
Just Married
#526 Blaeven
Blaeven
    The Renowned
  • 1,400 posts
Posted 21 February 2009 - 12:42 PM
i'll probably do the whole lot...
though, having said that... the place that sold them to me gave me a warranty... it's run out, but i called them and told them before it ran out that i was having problems and he said to just bring it in when i can
i called him on my way back from bris, but they closed at 4pm so i couldn't get there in time...
but he said to take the car in when i can and they'll check it out...
#527 Jeff
Jeff
  • 528 posts
  • Interests:Lee
Posted 21 February 2009 - 01:07 PM
so you'll be up this way some day soon?
Just Married
#528 Soop
Soop
    Suck, squeeze, bang, blow.
  • 3,483 posts
Posted 21 February 2009 - 03:47 PM
forget the Outback bar. Make the car fast.
TSM
#529 Shiv
  • 4,741 posts
Posted 21 February 2009 - 04:07 PM
They're no where near as uncomfortable as I assumed they would be. Quite tolerable actually...its only once you get on the bad surfaces that you really feel it. Small price to pay for big abilities in the corners though....shame his tyres aren't fully up to the job but thats an easy fix.
#530 DRIVER
DRIVER
  • Banned
  • 264 posts
Posted 21 February 2009 - 04:26 PM
So Tristan i take it your not buying my Outback... hehehehehehe
I dont give a f*ck how fast it is....there's no joy in threatening people.
#531 Soop
Soop
  • 3,483 posts
Posted 21 February 2009 - 06:48 PM
I didn't think it was possible to be both sarcastic and retarded at the same time. Thanks for opening my eyes Jovan.
TSM
#532 DRIVER
DRIVER
  • Banned
  • 264 posts
Posted 22 February 2009 - 12:38 AM
sure it can be both at once, but keep them eyes open, :lol:
#533 buddylove
buddylove
  • 550 posts
Posted 22 February 2009 - 08:11 AM
teins are fine, as you said. as soon only when you hit the roadworks does everything feel like a earthquake. me teins are set to full stiffness and it felt more comfortable then tristans car which is on soft. might be cause super streets are better for that kind of stuff/his are fugged i dunno.
MY07 GT-B 6MT Sedan
#534 Evil_VZ-T
Evil_VZ-T
  • 1,014 posts
Posted 24 February 2009 - 07:48 PM
Got a dyno sheet with the AFR's attatched? Hows the AFR's on cruise? Idle?
MY02 Liberty B4
#535 Soop
Soop
  • 3,483 posts
Posted 24 February 2009 - 07:53 PM
AFR? lol. They just stuck a hose in the inlet manifold.
TSM
#536 Blaeven
Blaeven
    The Renowned
  • 1,400 posts
Posted 24 February 2009 - 08:55 PM
he didn't want to put the AFRs on the dyno graph cos it shows how he tunes...
load of crap IMO...
the AFR sits around 13 for most of the chart... (running rich because it's safer iirc)
and it spikes up to 14 (maybe even richer) just before 4000rpm because he was worried about it pingging during the cutover from avls...
IMO it probably needs a retune by someone who tunes NAs... like a honda tuner or something... if it was leaned out and more timing pulled (and had a better flowing exhaust) it should make closer to 160kwatw
#537 Xon
Xon
  • 1,535 posts
Posted 25 February 2009 - 07:22 AM
Sounds like he's tuning a turbo...
#538 Blaeven
Blaeven
    The Renowned
  • 1,400 posts
Posted 25 February 2009 - 07:47 AM
he's a turbo tuner...
that's why i've got to take it to someone who does NA motors... (preferably hondas, so he/she can tune the vtak properly)
#539 fatcat67
fatcat67
  • 1,206 posts
Posted 25 February 2009 - 08:32 AM
Or get a standard ECU and sell the Vipec.
As Tony Montana would say:
#540 Blaeven
Blaeven
    The Renowned
  • 1,400 posts
Posted 25 February 2009 - 09:28 AM
standard ecu means i have to re-add a bunch of sensors to the motor, get a gen4 key barrel and key (programmed from subaru for god knows how much) and have the car re-wired... and i'm sure there are other things (maybe al can back me up here) too, that make it less viable than using a wire-in ECU... it just worked out to be a lot easier to run a wire-in ECU than the standard ECU...
