H6 engine
#561
Posted 25 February 2009 - 05:13 PM
#562
Posted 25 February 2009 - 05:44 PM
#563
The wideband closed loop fueling on the vipec uses the AFR target table for the corrections, works extremely well on my car. The acceleration enrichment also contributes to the detriment of the fuel economy if you're not light on the throttle and it's set too heavy.
Attached are two screenshots from the factory EZ30R fuel tables showing estmated AFR for subaru's load measurment. As you can see it runs around stoich at light load, and straight into the 13's with power and around 12 in the top end.
Also keep in mind that the factory ECU has more than 20 configurable corrections for knock control to stop itself grenading with the timing it runs, it will retard up to 7 degrees from the base map.
If you go for agressive timing and a lean mixture, all it will take is a bad batch of fuel to crack your ringlands as no aftermarket ECU has knock control as good as the factory ECU's which have hundreds of hours worth of tuning put into them.
I personally wouldn't run an EZ30R with AFR's in the 14's under significant load.
#564
Posted 25 February 2009 - 06:00 PM
thanks dude...
that's what i was looking for... helps me out heaps...
i think my problem is that there doesn't seem to be much difference between quarter throttle and full throttle for anything below 4k rpm...
meaning it's constantly running rich??
oh, and i haven't noticed any smoke.. but it's a little hard for me to check...
edit:
i've also noticed the knock sensors at work when it's cold and i try to rev it past 4k (when it looks warm on the temp gauge, i've got to give it another minute before i get up it even a little bit) because it sort of pops and stutters and won't really rev much (i haven't pushed it... i'm not an idiot)
#565
Posted 25 February 2009 - 06:04 PM
#566
Posted 25 February 2009 - 06:14 PM
#567
Posted 25 February 2009 - 06:18 PM
#568
Posted 25 February 2009 - 06:20 PM
#569
Posted 25 February 2009 - 06:25 PM
#570
Posted 25 February 2009 - 07:02 PM
so it's confirmed to be running in the 11's? I didn't think Blaeven had a wideband in it yet?
Also regarding the "knock", if you hit a soft revlimit while it's cold the engine noise generated can look like knock. That's another reason why it takes a fair amount of work to setup the knock table properly. Lots of datalogging to be done, and as you know Mark did not want to push the limits of knock on your engine with cast pistons. They're a lot easier to break when finding the limits than with a set of forgies.
it only drops to 11 (i think it goes that low) at WOT at about 3800 (before the cutover to AVLS)
i don't know what the AFR's are for the rest of the tune...
i'll plug a laptop into it soon... i'm assuming i'll need some sort of Vi-PEC software first??
and i don't think it has a lower rev limit in place as it will still rev if i push it (i think...) i just don't want to because it doesn't seem to like it...
#571
Posted 25 February 2009 - 07:14 PM
#573
Posted 25 February 2009 - 08:27 PM
#574
Posted 25 February 2009 - 10:04 PM
It appears my understanding of the whole conversion proces may be a tad simplistic and I most certainly don't know a lot about this stuff, but this is what I understood for example:Frank - If a factory ecu could be used on this engine I would have used it. There are many problems related to using a factory ecu on a Gen 4 engine relating to the CAN communication system between modules. These problems could well be overcome with research but the only immediate solution is aftermarket ecu's and the Vipec is the only one that will run the engine properly in Australia.
Ver8 STI into a Gen2, use Ver8 ECU and loom with Al weaving his magic.
Ver4 STI into a Gen1, use Ver4 ECU and loom with Al weaving his magic.
EZ30 into a Gen2, use EZ30 ECU and loom and Al weaving his magic.
Aren't all the sensors/modules the same as the stock ECU would be utilizing?
If this isn't quite the case then this is the kind of stuff that we'd love to understand and learn about.
#575
Posted 26 February 2009 - 12:11 AM
#576
Posted 26 February 2009 - 01:12 AM
IIRC from reading many of Az's EZ30+T build threads on RSLC they/he/it ran into issues with the amount of inputs.. or was that a different ECU...One Quick question Al in regards to the Vipec being the only ECU able to run the EZ30R....
Why can a Motec M800 or something like that not do this? is it just because the Motec is too expensive and not a viable option or is there something the Vipec has that the Motec Doesn't? I have always thought the Motecs were a pretty good ecu able to handle anything and was suprised to read you say the Vipec was the only one able to do it?
(this is not critisism I promise.. just really curious to learn)
/Waits for Al to slap me around a bit and call me a retard
Posted 26 February 2009 - 06:38 AM
#578
Posted 26 February 2009 - 07:25 AM
#579
Posted 26 February 2009 - 09:46 AM
#580
Posted 26 February 2009 - 10:43 AM
