does that connect to the wiring harness? never seem one of them before lol
Powered Antenna to Aftermarket Head Unit?
Started by tamastar, Apr 25 2013 04:39 PM
aerial antenna powered antenna powered aerial stereo audio help electrical wiring
21 replies to this topic
#21
Posted 29 April 2014 - 01:50 PM
#22
Posted 29 April 2014 - 02:08 PM
Yeah, basically all you need to do is splice into the 12v supply thats already there for your head deck, ground the actual aerial booster. Then test it just sitting in behind your dash, if the signal isn't strong enough with it just sitting in there you can run it to your rear de mister and use that as the aerial, because the male lead on the booster is about 3 metres long I think from memory.
Also tagged with one or more of these keywords: aerial, antenna, powered antenna, powered aerial, stereo, audio, help, electrical, wiring
Tech: The basics →
Electrical/Electronics →
2 Aerial cables conversionStarted by podmak, 09 Mar 2024 ![]() |
Tech: The basics →
Tech: The basics →
Check Engine Light Is Constantly On!!!Started by Luke96, 08 May 2017 ![]() |
Tech: The basics →
Naturally Aspirated →
HELP! what is this noise?Started by zacsuby, 02 Jan 2017 ![]() |
Suby Club Community →
General Discussion →
In need of help with my rear end. Rwd subyStarted by Westonw14, 23 Oct 2016 ![]() |
