DIY: Rectify Light Steering
DIY: Rectify Light Steering Twin turbo SUBARU Legacy SUBARU Legacy JDM BH5 MY99 Tw
36 replies to this topic
#1 L A R V E N
L A R V E N
  • 20 posts
  • Interests:Skating, Snowboading, Subaru, BE5
Posted 18 October 2011 - 11:00 AM
- Model of car DIY is being performed : SUBARU Legacy JDM BH5 MY99 Twin turbo GEN3
- Aim: Takes away the Speed Sensitive Steering settings.
- Tools needed (if any) : Torch, 10mm Spanner or Shifter
- Rough costings and source of parts (if possible) : $0 Free - Depending if you have a torch or other hand tools.
- Warning: Please use this information with caution, as it's a change that should be made carefully as this could have an impact on other setting..
this is only for instructional purposes only, If you choose to use this information you do so at you own risk.
- Article Found: uklegacy.com
- Instructions:
  • Disconnect battery (Using 10mm spanner or shifter).
  • Under the driver's side there is a box to the right hand side of the steering column (Use a torch as its normally dark under there) disconnect the white plug (Picture Below)
  • Reconnect Battery. (Using 10mm spanner or shifter).
  • Now go for a drive.
Below Picture of the box and plug
#2 buzzda
buzzda
  • 3370 posts
Posted 18 October 2011 - 11:27 AM
Just curious, what's the benefit of doing this?
#3 L A R V E N
L A R V E N
  • 20 posts
Posted 18 October 2011 - 11:39 AM
Not much LOL... if you have driven a car with the settings on it feels weird maybe to light.. feels more stable, like I now have more feeling. But at the end of the day its personal preference. Just makes it feel sable. Its hard to explain... on my model bh5 its really to light at low speed but now it feels heavy
#4 12.SLOW
12.SLOW
  • 397 posts
  • Interests:cars
Posted 19 October 2011 - 03:00 PM
does this work on gen 2 liberty's
Slower Then The Rest
50.CYA
YAMAHA R3 2015
#5 Ben_20EJT
Ben_20EJT
  • 2397 posts
Posted 19 October 2011 - 03:28 PM
dont belive your car has speed sensitive steering mate. just good old power steering.
#6 Alex
Posted 19 October 2011 - 06:25 PM
shonkiest.
diy.
evah.
#7 FR34KO
FR34KO
    GRANDMA's BOY
  • 2461 posts
  • Interests:SNOWBOARDING.
Posted 19 October 2011 - 06:53 PM
^ lol.. :)
#8 Jovi
Jovi
    When one set of Twins is Just not enough.
  • 453 posts
  • Interests:When one set of Twins is Just not enough.
Posted 19 October 2011 - 06:56 PM
Chris your old etune is strange as mine sure does not have this...
#9 Xon
Xon
  • 1535 posts
Posted 19 October 2011 - 07:57 PM
If you want heavier steering, remove the power steering pump. Only JDM cars came with these variable steering systems.
#10 Alex
Posted 19 October 2011 - 08:12 PM
You'll find Luke, that it's actually the rack that needs to be replaced to remove the variable power steering, as they have an electric servo in the rack itself, and when they overheat, they fail, leaving the steering switch like crazy between heavy and light.
JDM 2.7:1 rack FTW.
#11 Xon
Xon
  • 1535 posts
Posted 19 October 2011 - 08:20 PM
My comment was aimed at quietone Alex, who owns an AUDM gen2 RX, which does not have an electronically controlled variable rack.
#12 Alex
Posted 19 October 2011 - 08:28 PM
Fair enough
It's not a good idea to run a power steering rack without fluid, but rather as the manufacturer intended, as rack failure would be very quickly imminent.
If a manual rack is desired, the rack itself needs to be converted.
Retarded.
Refer to JDM 2.7 rack comment.
#13 Xon
Xon
  • 1535 posts
Posted 19 October 2011 - 08:32 PM
It was a joke ;-)
#14 L A R V E N
L A R V E N
  • 20 posts
Posted 19 October 2011 - 08:45 PM
I know right..! Lots of little things are so different...
shonkiest.
diy.
evah.
LOL - I know, but hey :blush:My next DIY post will be WAY BETTER and less on the shonky side...
BUT it does work, and there is so much more control...
#15 Alex
Posted 19 October 2011 - 08:57 PM
It was a joke ;-)
So funny.
Looking forward to it!!
#16 Matt
Matt
  • 4380 posts
Posted 19 October 2011 - 09:16 PM
JDM 2.7:1 rack FTW.
True dat....
But JDM 2.4 (STi RA) rack FTMFW!!
(i cant wait to fit my S201 rack! ;))
#17 Alex
Posted 19 October 2011 - 09:50 PM
You're getting a 2.4 rack Matt?
You animal! You'll hiccup and swerve over three lanes on the freeway!
#18 Matt
Matt
  • 4380 posts
Posted 19 October 2011 - 09:57 PM
I have one sitting on the back table atm ;) from a s201!, ive been on the list for about a year now than my name came up! Only $300 delivered and looks tight as, just needs a slight scrub
Came with a schmick set of AVO bushes too!
And yeah skippy said dont sneeze on the highway lol
#19 Alex
Posted 19 October 2011 - 09:59 PM
where did you score one from? Skip?
Can't say I need one... but... you know how it is.... :P
#20 Matt
Matt
  • 4380 posts
Posted 19 October 2011 - 10:09 PM
Yeah skippy, they come in extremely rarely so he has a list setup.
I put my name down febuary of 2010 andl i was about number 15 back then...he rang me a few months back and said one was coming in and i was on top of the list!! Unfortunantly that v6 RA had the rack removed by someone in japan so i waited for the s201 to come in and BAM its now mine :D
Keen to install it, should be crazy compared to my crappy stock RX 3.something pathetic rack
And its STi so its gotta be good lol
Also tagged with one or more of these keywords: DIY: Rectify Light Steering, Twin turbo, SUBARU Legacy, SUBARU Legacy JDM BH5 MY99 Tw
