Posted 20 July 2012 - 02:29 PM
My car is a 95 GX liberty sedan.
So far I am planning to replace my clutch and front driver side cv boot.
I have been told by subrau that my flywheel is not dual mass, which I have read a bit about (consensus seems to be that it is a pos). Correct me if I am wrong.
Found this exedy clutch which fits (hopefully) and seems to be alright for the price. Comes with everything I will need from what I can tell. http://www.autoparts...ngs+Best+Seller
I also plan to replace the gearbox and rear diff oil, rear main seal and machine the flywheel. Are there any other things that need to be done when replacing a clutch that I have missed?
Found this DIY clutch replacement for an impreza, which is extremely well done. I assume the process would be very similar for my car so I plan to follow it pretty closely.
http://www.rs25.com/...-pictorial.html
My front driver side cv boot has shat itself and flung grease everywhere in the last couple of weeks so I was wondering, is it smarter to just replace the entire axle instead of just the boot. The car has nearly 250,000km on it.
Any help will be greatly appreciated.
Thanks,
Josh
Posted 20 July 2012 - 02:33 PM
I can't help you with the other clutch questions but re the CV boot, is it clacking when you turn corners yet? If not, you might have caught it in time and will only need to replace the boot. If the joints are clacking or if too much crap has made it's way inside the split boot, you'll need to replace the whole driveshaft.
Posted 20 July 2012 - 02:40 PM
Correct, your car has a solid flywheel - this is a good thing!
There is a small amount of noise on full lock, so I guess I'll be replacing the entire thing.
Thanks Morgan
Posted 20 July 2012 - 02:43 PM
I've bought new drive shafts at Bursons West Gossy before for about $140 from memory (it was about 3-4 years ago).
Posted 20 July 2012 - 02:49 PM
I'll have a look at Bursons later this afternoon.
Thanks a lot
Posted 20 July 2012 - 02:51 PM
Might be worth asking them for a price check on flywheel/clutch/seals/oil too?
Posted 20 July 2012 - 02:56 PM
Posted 20 July 2012 - 02:58 PM
Posted 21 July 2012 - 03:07 PM
Posted 21 July 2012 - 10:50 PM
Also tagged with one or more of these keywords: clutch, axle, flywheel, gen2, cv
Model Specific →
Liberty / Legacy / Outback →
Body →
Gen1, Gen2, Gen3 window differencesStarted by El_Freddo, 29 Dec 2016 Gen1, Gen2, Gen3, window glass and 4 more... |
Model Specific →
General Discussion →
Dual Mass FlywheelStarted by El_Freddo, 22 Oct 2016 Dual Mass Flywheel conversion and 3 more... |
Tech: The basics →
Twin Turbo →
Heavy duty clutch kit for B4 & gearbox bearingsStarted by LukeFranky, 15 Sep 2015 Clutch, Gearbox, Bearings |
Model Specific →
Builds and Projects →
The Mexicans are Building a Racecar/Project BitsaStarted by Barbbachello, 29 Aug 2015 racecar, bitsa, gen2, skids |
Suby Club Community →
Will a gen2 wagon exhaust fit a gen3 sedan...Started by Leemanchew, 11 Jun 2015 gen2, liberty, legacy, gen3 and 1 more... |
