Posted 14 June 2012 - 11:35 AM
i've had this problem since i got my car last year, was told it was the rear right sensor, got a second hand one from sunspares, replaced the old one which was clean (also turns out it within specification 1.2K ohm, good on ya subaru for just hooking a computer up but not checking). I've checked continuity from the sensor into the harness in the drviers side foot well and there is no problem. Visually looking through the abs hole, the tone wheel looks ok, but it does have some faint scratches on it.
Any ideas?
Thanks
Posted 14 June 2012 - 11:36 AM
Turns out the ABS unit itself was faulty/incorrect.
Swapped it out, and it was good to go.
Shazza
Posted 14 June 2012 - 08:17 PM
Good you checked resistance but you should also check sensor output to confirm it's signaling the ABS ECU.
The sensor outputs a A/C voltage as the wheel rotates. From memory its about 0.1- 1v depending on wheel speed.
As wheel speed rises, so does the voltage (amplitude) and the pulses speed up (frequency increases).
You can test the voltage output with a multimeter set to A/C volts.
Posted 15 June 2012 - 10:35 PM
It was 400 odd for a new one and it was on back order from japan so it would have taken 6 month (or more) to get it in.
Sunspares had a used one with guarantee so got one of those, annoying thing my original one come up to spec in resistance, but i would have expected subaru to check the sensor as i had asked them too and not just rely on the computer.
Since its just a matter of hooking up the multimeter on AC to check the voltage thats a quick one i can check too, thanks!!!
Next one i'm going to check is from the harness in the drivers side foot well to the connector at the ABS control unit.
Posted 15 June 2012 - 11:32 PM
If Subaru said it was the RR sensor and the 'damaged' sensor is giving out a reading within specs, Switch a sensor over and see what happens to rule out a dodgy sensor.
Check all wiring before replacing the ABS unit, Hopefully it's something simple.
Posted 15 June 2012 - 11:44 PM
Does anyone know if the ABS code faults need to be cleared before the light goes off? As that is what subaru is telling me and want 110 to clear it.
However, the light did go off for a day when i disconnected and reconnected the the sensor once. Which makes me wonder if i really need to clear it.
Posted 15 June 2012 - 11:58 PM
Posted 16 June 2012 - 01:46 PM
Where abouts are you from?
Posted 16 June 2012 - 03:31 PM
SW49ON im from canberra. Does anyone know how to clear the ABS codes without the scan tool?
I had access to a OBD2 scan tool but it came up with nothing, i don't think it picked up ABS codes only engine codes.
Posted 16 June 2012 - 05:51 PM
I has the 16pin plug but Im sure it runs a different protocol.
Posted 16 June 2012 - 09:47 PM
Posted 17 June 2012 - 08:29 AM
I could be wrong but I scanned mine the other day and had no "P" codes. Mmmmmm might look again.
None of this will help with your problem though!
You could try leaving the battery disconnected for a while but I doubt it will work. Most likely you will need a scan tool, espcially if its OBDii.
Posted 17 June 2012 - 11:31 AM
Also tagged with one or more of these keywords: abs, sensor, gen3, genIII
Model Specific →
Liberty / Legacy / Outback →
Builds and Projects →
Model Specific →
Engine / Driveline →
Gen3 sedan and wagon rear end the same?Started by El_Freddo, 30 Apr 2017 Gen3, gen3 suspension and 1 more... |
Model Specific →
Body →
Gen1, Gen2, Gen3 window differencesStarted by El_Freddo, 29 Dec 2016 Gen1, Gen2, Gen3, window glass and 4 more... |
Model Specific →
Bennie's sister's Gen3 RX Liberty WagonStarted by El_Freddo, 29 Oct 2016 Gen3 Liberty, Gen 3 Liberty and 2 more... |
Model Specific →
Body →
Gen3 outback with liberty bodykit??Started by CuereusGeorge, 01 Aug 2016 outback, liberty, gen3, wagon |
